I use the finger print and the 4 digit lock screen functions on my Z5c.
For some reason, although I have the 4 digit lock screen option set, I can swipe up and it will unlock.
When I go in to the Security menu and click on Screen Lock and enter my 4 digit code, the Pin option states the following:
"Because you've turned on an accessibility service, your device won't use your screen lock to enhamce data encryption"
I did have both the finger print option and the 4 digit lock screen option working together properly, but now it's not working properly.
The finger print option is working fine, any ideas what's wrong with the 4 digit lock screen option ?
Thanks
Bobby
No problem! Happy to help! :smileysmileythumbsup:
