I am planning to get either XZ Premium or XZs. I checked both specs it seems like they're the same. Any suggestions which one is better than the other? Thanks
Hi @Trizagger13,
First and foremost, both are great devices and you can't go wrong with either of them!
However, there are some differences between Xperia XZ Premium and Xperia XZs, I will note some of them for you:
- Size and weight. XZ Premium is a larger device in comparison to XZs, so it weighs more. XZs dimensions are 77x146x8.1mm, and weighs 161g while XZ Premium is 77x156x7.9mm and weighs 191g.
- XZ Premium has an upgraded processor as it uses the Snapdragon 835 Octa Core processor, while XZs uses Snapdragon 820 Quad Core processor. In addition to the processor, XZ Premium uses Adren 540 GPU while XZs uses Adren 530.
- XZ Premium has a larger battery
- XZ Premium has the worlds first 4K HDR Display, it is 5.5" while Xperia XZs has a Full HD display at 5.2"
With that said, it's all up to personal preference!
I hope that helps!
Do you know why weight of XZ Premium changed from 195g to 191g?
Thanks for the info! ☺️ I'm still kinda torn between them but thanks a lot!
@ds2mph Ah, my mistake, great job pointing that out for me! I had mistyped the weight, I am sorry about that - 191g is correct as in accordance to the product specification page found here.
@Trizagger13 I understand that, I am kind of torn as well, but knowing me I will probably ending up getting both, haha! Feel free to let me know if you are wondering about anything else specific which may ease the choice and I'll do my best to answer!
