Just received Andoid upgrade to 10 52.1.A.0.532 - most of the functions seems to work without any hassel. What I recognized is, that the fingerprint reader is responding with a much bigger delay than before - seems to be a high lag time. Anybodey else with same xperience or any other issues?
The Support says, they dont even know about this yet
I - unfortunately- can only announce similar issues with my updated XZ2:
- higher battery usage compared to last week (without update)
- fingerprint reader is slower, if working at all. Sometimes working when display is off, sometimes after 2 or 3 times trial.
- alarm does not work properly
- "smoothness" in usage is gone. apps take longer to load, transition from screens is lagging.
All in all it works far from perfect - as it did last week.
In addition:
since some months the usb-connection towards PCs does not work anymore. The device is not recognized by windows and the XZ2 does not recognize the pc, does not allow any change of the USB mode.
I tried 3 different PC and 3 different cables.
Funny thing: USB-otg camera and other stuff is working.
I am really starting to hate the Sony XZ2.
BR
Markus
I noticed the fingerprint delay too at the XZ2 compact.
I have to press stronger and longer to to unlock. More often the fingerprint is not respoding.
Anyway it's no more working smart like before.
A technical statement would be interesting if this is a higher security check from the android system 10 and needs more sensitive hardware-sensors to compensate, or if it can be fixed by a future update.
I before used one accu charge for 3 - 4 days with most on standby and only short usage.
I miss the nice discharge graphic and I fear the accu is only for 2 - 3 days now.
May the force be with Sony.
Discharge Graphic still can be seen - at least for my XZ2.
But I need to go to the battery-settings and then hit the * ... * in the upper right corner to see the battery graph.
Fingwerprint-sensor: #me too# !
Here another one with the same problema on XZ2 compact. Too much lag. Slow. Fingerprint. Notifications appear after a long time. Worst update ever!
Glad i'm always last with my Hongkong 6GB Version regarding updates.
Disabled automatically updates, thanks for letting me know
I will Stay on Android 9 until stable 10 version is available.
Opt for Google keyboard instead
I am using H8296 and I didn't received the update yet.
