XZ1 screen issue
YML93
Visitor
XZ1 screen issue
navigation bar area is display not normal.
4 REPLIES 4
RizkyRizz
Visitor
Restart?
Safe Mode?
Factory Reset?
Software Repair?
YML93
Visitor
I have repaired software by xperia companion, but it's no use.
Not applicable
It looks like a screen retention issue, contact your local support. They will most likely replace the screen if it's under warranty
RizkyRizz
Visitor
Try to Flash into another region
Have you?
