hi everybody,
I left my phone charging in the night(it was on) and when i came to take it in the morning (it was off)... i tried to turn it on but it didn't turn on!
(IM USING ORIGINAL SONY CHARGER AND USB THAT CAME WITH IT)
when I plug it in to a charger the LED turns green (that means that the battery is at 90% or above)
i tried power and volume up (hard reset) but it didn't work!
when i connected to my computer it wasn't detected....(tried all USB ports)
Also, i tried to enter Flashmode and Fastboot mode.. and none of them worked!
Xperia companion didn't detect it....
I tried to turn it on several times but it didn't work!
i even tried all buttons combination (power, both volumes ) all together, and nothing worked!
PLEASE HELP ME!!!
please anyone have an idea or any suggestion that might help!
all your suggestions are so much appreciated!
THANK YOU VERY MUCH!
Thank you so much. It's really works!
Thank you
And do you know why this thing happens?
My Sony Xperia XZ Premium just shut down and won't start. Is it software or hardware problems?
I have the same problem. I left the phone on 80% battery and went to sleep. When i woke up i cat turn on my phone. Long reset does nothing. All i get is white led light flashing in intervals. How do i start my phone l, i tried changing and it didn't help
