All,
Just looking for a bit of advice on battery/charging issues with an XZ Premium. I just want a second opinion on whether the issues below are battery related or due to a wider issue to decide whether or not to repair.
This morning I had a camera error - "error: unknown error" when trying to use my camera. The flashlight also wouldn't work.
I then discovered a series of other issues relating to the battery/charging of the phone and I'm trying to establish whether these issues are all related or whether a replacement battery is required. With relation to battery:
Query is, would a slight tear in this cable result in the phone not charging but working via the mains, or, are these issues suggesting something more.
It's really a question of do I try a replacement battery or replacement phone!!!
Thanks in advance.
hello @avdgfc
I would suggest to have the phone checked by an authorized sony service center near you. https://services.sony.co.uk/supportmvc/en/contact/
mostly likely your warranty is already void, so they might charge a fee for repair, you can decide then if the fee is justifiable for repair or not , then you might consider buying an upgrade..
Stripped phone down, installed new battery and battery/charging issues have gone. Believe the tear in the battery flex cable was the fault and reason why the phone wouldn't hold a charge but fixed and all resolved.
Thanks in anycase
