Hi Guys,
I am facing an issue with my new XZ, it gets heat up, hangs a lot and also battery is draining very fast almost in 5 hrs with normal usage.
Kindly let me know if it's due to software or the piece is faulty.
I have updated my XZ to 7.1.1
Thanks and Regards,
Abhinav Agarwal
If you have issues after a software update, try performing a backup using Xperia Companion and then a software repair using Xperia Companion
its normal to heat up after externsive use on a game or video camera in Full HD or 4K.
However I experienced heat up and battery drain due to a faulty process. not hardware related.
check it here
same happening with me. It gets heated up while using normal apps and hangs a lot
