My hubby is having trouble with his xz. Its like something is interfering with it. Its flashing and twitching between screens and is totally unusable in the house. Took it to shop and it didn't happen and worked fine.
Has anyone else experienced this?
I think a repair is necessary given the information you have provided. Looks like you are on the right path.
Hi @Hayeshouse, welcome to the community.
This sounds very strange... Would it be possible for you to upload a video of the issue to somewhere like YouTube, then post the link here?
I will not be able to access a whatsapp message here. Uploading to Youtube from a phone is usually very easy, when you see the video press the share button, and share it with YouTube.
Based on your description though, I cannot tell whether it is a software issue or hardware. Does it happen in safe mode?
Hi @Hayeshouse, thank you for this! I can clearly see the problem now.
Do you have a screen protector on your device? Or do you see any hairline cracks?
Also, does this happen in safe mode?
