Hello everyone!
Smart launch is a new feature on the Xperia XZ3 and you can read more about it here.
Please let us know what you think about this new feature!
This feature is absolutely superfluos.
It´s ridiculous, unneeded and distracting.
Sorry, but who needs a camera self activating if it is pulled out of pocket, when there are several other possibilities to turn on camera. Including a dedicated camera switch.
For me this feature doesn´t make sense. Would be nice if you don´t sprip good features like xperia Actions and Xperia Backup.
Kind regards
Can Smart Launch be deactivated?
@airscrew wrote:Can Smart Launch be deactivated?
Yes it can, in camera, open the settings and scroll down, there you will find options for smart launch.
This is really bad implemented...My phone was completely quiet on top of a table, and without nobody touching it in any way the screen was waking up randomly without any apparent reason. After some time I found out that was the movement on the front camera that was triggering the waking up and after losing even more time I reached to this feature, disabled it and everything is ok!!! If you want to turn on the camera after lifting up the phone and holding it horizontally at least check the sensors to see that there was movement (preferably using a signature for the movement with some standard deviation) and DO NOT rely on the camera movement only.
Hello,
The smart launch is a Camera app feature allowing you to launch the camera and take a picture when lifting up and holding the device in landscape view and aiming it towards an object. The smart launch will work even from the lock screen or a turned off the screen.
You should try that feature via Camera > settings icon (cogwheel) > Smart launch.
Thanks and Regards
Afflospark
Smartlaunch is a software platform for managing an eSports center and its customers.
Smartlaunch consists of three powerful software applications: Smartlaunch Server, Smartlaunch Administrator and Smartlaunch Client.
Smartlaunch Server is installed on a dedicated server machine which provides balanced performance and storage capacity. A center's games and applications are usually stored on this server.
Smartlaunch Administrator is installed on a PC and is used to manage a center's customers; monitor the center's computers and applications; tracks their usage and handles payments
Smartlaunch Client is installed on each PC at a center and provides games and applications to customers for creation of an entertainment experience in a secure environment.
Supported Operating Systems
Windows 7, Windows 8, Windows 10, Windows Server 2003 Service Pack 1, Windows Server 2003 Service Pack 2, Windows Server 2008, Windows Server 2012
After downloading the Smartlaunch Installer, start installation by double-clicking the installer
Smartlaunch installs any of the following prerequisites, if missing:
.NET Framework 4.0
Microsoft Visual C++ 2012 Redistributable x88
Adobe Flash Player (Flash Player content debugger for Internet Explorer - ActiveX), Crystal Reports (32 bit) mcdvoice
Kinda think you over thought this one dude.
Once you have installed the Smartlaunch Server on your server computer you can launch it directly from the shortcut on the desktop. As soon as the server has completed the loading process it will appear in the system tray in the lower right corner of your screen walgreenslistens
