Hello everyone!
Ambient display is a new feature on the Xperia XZ3 and you can read more about it here.
Please let us know what you think about this new feature!
Hello,
Ambient display is a feature that allows you to see information such as time and notifications without pressing the power key.
A smart feature which allows seeing notification without pressing the power button. You can activate via (Settings > Display > Advanced > Lock screen preferences > Ambient display).
It will activate when any movement happens. If you want to disable it either you disable via settings or you use a smartphone cover.
Thanks and Regards
Afflospark
nothing on my Pixel 2 XL, 3 XL or 4 XL. my guess is this is meant for non-Pixel phones, since those that got it are all non-Pixel.
sorry Google, I'm not going to get a $100 wireless charger just for this feature when it is supposed to be included as is. Walgreens Listens
