Greetings everyone,
I recently bought a 3.0 usb flash drive (Silicon Power B30 128GB) to store movies and play them on TV. I formatted the flash drive to exFAT and I use a 3.0 USB-C adapter (not cable) to normal USB female port for connecting the flash drive to phone. The transferring of files is unbelievably slow. Also when it's detected and the notification appears, the charging usb device is selected by default and I can't choose any other option, it always reverts to default. I read that I should try restarting the phone with the drive connected (don't know why) but nothing changed. The flash drive worked properly when I tested it on pc after reformatting it. What's the deal?
Sidenote; Before using this new drive I was using a card reader with the phone's SD card and the same usb-c adapter and it worked properly.
@Sethunawrote:Greetings everyone,
My transcend USB 3.1 to USB C 64 GB OTG is running normally and fast just like transferring files to PC if I use it on my XZ.
I can play video files on that OTG directly while connected to USB C of the XZ. I thinks it's the fault of your OTG.
Can you provide a link of the product or something else, cause I'll probably buy it and give it a try. I can't find it online.
