Phone is unable to connect to a car radio or dvd player - gives error message N/A USB or USB ERROR
it isn't supported, usb connection is based on MTP, which is for file transfers only.
if you want to connect your device to car stereo, you can use a 3.5mm aux cable then use voice commands to navigate music. or use wireless options
