x
Setting Wifi Preference
profile.country.GB.title
cosmarchy
New
My XZ3 is having difficulty with a particular wifi.
When I am at home, it connects to the home wifi without any issues but it never seems to connect to any other wifi which I have saved, without me having to manually connect.  It prefers to try and connect to a very slow mobile signal rather than connect to the perfectly good wifi only a few feet away with high signal strength.
Since this is Android 10, I don't appear to have any auto connect settings.
Can anyone advise what is going on here and what the fixes are?
Thanks
1 REPLY 1
Piscie
Community Team
Hello @cosmarchy, it seems to be a software bug, try to reset the network settings (Press settings - network & internet - mobile network - advanced - access point names - tap the three dots on the corner and select reset to default)
Let us know what happens.
