I have trasnfered several apps to SD card from internal memory.
But if I update the apps in the Google Play, they return back to internal memory.
For example,
1. I have moved Instagram app to SD card.
2. Google play notify me there is an update.
3. I made the update.
4. Instagram app is located in internal memory, not in SD card.
5. I have to transfer the Instagram app to SD card again.
Is this a normal operation??
That is how it works, it has been asked before. There is a good explanation from Rickard here:
