Hey everyone! The purpose of this thread is to ask anything that you wish to know about the XZ Premium; other users owning an Xperia XZ Premium and forum staff will do our best to reply!
As an example, prior to purchasing an Xperia XZ Premium you may be wondering if someone has tried out a specific third party app or feature on their XZ Premium, and could tell you a bit more about the compatibility and functionality as the app may important in your daily life. Staff and other users can come in and reply and let you know how it works!
The goal of this thread is to help each other out as a community. We will try to moderate this thread so that any new threads with a fitting question will instead be moved here, while we of course keep support threads the way they are now.
NOTE:
Support related questions, such as raising concerns and troubleshooting are best suited in a different thread. Please try to see if there is a thread regarding your concern, and if not, feel free to create one!
i recently looked at videos of the Sony XZ's camera in youtube and found it has a lower resolution setting (2MP) which is good for low light photography and a lot more camera apps. My XZ premium doesn't have the low res option (2mp). Will there be an update to have it?
No supported apps for the tag installed on the devise
@Krister00 what tag are you talking about?
Hi, I was having xperia Z5 dual and the camera app had a lot of built-in or downloadable, supporting apps. for example, multi-camera and many others.
recently i've got a new XZ premium and see that these are missing.
Is there a way to get those apps to my XZP as well?
Why, after updating the brightness slider moves by itself, is there anyone else that has this problem?
GT
@Dimas94 wrote:Почему после обновления ползунок яркости двигается сам по себе, есть ли у кого то ещё такая проблема?
do you have automatic brightness enabled? if it's bothering you, you can disable it in Settings > Dsiplay > Adaptive brightness.
I'm concerned about battery life span on Xperia XZ Premium. How should I charge this phone? Should I always charge to full 100% or is it true what people say that charging always between 40-80% is the best way to keep battery healthy? Also is quick charge 3.0 bad for battery? Is it worse for battery than usual charger? I'm concerned about this because my Xperia XZ Premium shipped with Sony UHC 12 which seems to be a quick charger that supports qc 3.0. So should I use this charger for daily charging?
Thanks!!
I really want this feature. Please bring it back and allow user to enable/disable this function
@Sonytist wrote:I'm concerned about battery life span on Xperia XZ Premium. How should I charge this phone? Should I always charge to full 100% or is it true what people say that charging always between 40-80% is the best way to keep battery healthy? Also is quick charge 3.0 bad for battery? Is it worse for battery than usual charger? I'm concerned about this because my Xperia XZ Premium shipped with Sony UHC 12 which seems to be a quick charger that supports qc 3.0. So should I use this charger for daily charging?
Thanks!!
I wouldn't worry about it. Sony uses some tricks like Qnovo adaptive charging and Battery Care that are meant to improve your battery life span. just charge whenever you feel like you need to.
Hi guys, i have two questions.
1- How to delete just A number from call record?
2- There is an alphabet on right side of contacts past series of Xperia. But i couldn't see this on xzp contacts.
Regards.
