Hello.
Will there be any updates that allow infinite loop screen on xz2C?
Any plans for implementing some noise reduction for the slow motion videos shot in low light?
@Gusterolog while Xperia Home doesn't support the infinite scroll thingy (going from the last page to the first one directly), you can try some launcher apps from Play Store. I know for a fact that Nova Launcher has such setting both for the home screen and for the app drawer!
Hi @Gusterolog
and welcome to the community
I´m not sure if i understood of what you mean about "infinite lopp screen". Are you refering to an Live Wallpaper?
About the noise reduction, do you exprience that with HD or Full HD options?
1. I mean like the one Huawei has when you can swipe the screen and then at the last page you can swipe back to the home screen.
2. Noise will appear nonetheless in low light while shooting slow mo, I'm just curious to know if there will be any kind of post process of that noise available in the future.
Hope that makes sense
Hi @Gusterolog;
1.In the settings menu of the home screen you have an option to hide apps icon, if you turn that on you can swipe up to access all the apps.
2.It is absolutely normal to get noise in low ligth shooting of super slow motion, because of time the shutter is open in this modes, it is just not enough time for enough light to enter, you have to shoot in good ligth conditions. I am shure the other brands devices like Samsung S9 and S9+ have the exactly same problem. Don't know however what the future reserves since these things are always improving.
