Ciao a tutti ho a
acquistato un Sony xperia xz2 compact e sto riscontrando problemi con lo slom motion xke avviene il farfallio e la risolrisouzione non è buona ma molto scarsa xke? Ho provato fuori con molta luce e il problema diminuisce ma resta comunque.... Come mai che devo faref
Hi everyone I have to purchased a Sony xperia xz2 compact and I'm having problems with the slom motion xke happens the phallic and the resolution is not good but very poor xke? I tried out with a lot of light and the problem decreases but it remains anyway .... How come I have to dof
-GT
@Giummo please post in English. it's a global forum so more people will be able to understand you that way.
because of the high shutter speeds used in super slowmo mode, you need a very good lighting in order to reduce noise.
you can also change super slowmo resolution to 1080p if you feel like 720p is too low, but keep in mind that the slowmo duration will be then shorter.
