I charge my XZ last night with normal like everyday.
In the morning my XZ it's OFF
i'm try every thing to turn it's ON but now still off
please help me. (T T)
If you still can't perform a software repair and the behaviour persists, then I'm afraid that the next course of action that I recommend would be to have you device sent to an authorized service center. I advice that you get in touch with your Local support for further assistance in doing so, as they are well informed regarding local consumer laws and service routines.
Keep me updated!
Hi @Drive7726, so sorry to hear about that.
Could you try what @Don82, holding down the power- and volume up button until the device vibrates and then try to boot it? Alternatively, try removing the SIM- and SD cards and then try starting the device while having the charger connected. If it still does not boot, have it charge for at least 2 hours (if you haven't already, please try a different power source to see if that helps) and then try starting it again.
Let me know if that helps!
i am already try this solution but nothing happen sir
when I plug a charger cable in.
a charging light is not illuminated
and nothing happen sir
While the carger is connected, could you try pressing and holding down the power- and volume up buttons simultenously again, but this time for 120 seconds (2 minutes)? If it still does not show any signs of life, please try performing a software repair using Xperia Companion using a computer to see if that helps.
Keep med posted!
I try to hold restart a device.
And then try to connected a device to PC companion software but it does not work.
PC companion don't see my phone.
it still cannot see my phone.sir
Hi @Drive7726
My suggestion for your situation and problem is the following:
1) Charge your device for 2-3 hours;
2) Turn on your device without SD card and SIM
If the device turns on (try few times), I suggest you:
1) Factory reset (App>Settings>Backup & Restore>Factory Reset);
2) Download the latest version of Xperia Companion;
3) When is showed the "welcome screen" after the factory reset, plug your device to the PC; it might be recognized now;
4) Software Repair procedure.
However, the problem of these spontaneus reboots will be fixed in the next update according to a tweet of this support team.
For now you can try this procedure and let know if it helps!
