Well, I would ask if there's something like painful or "manicure" or something like that to color the place which it's dechest means it has no color = white, is there?
I clean my phone sometimes with alchool, but I keep it away of battery place, keys, speakers and...
It make it looks awesome and clean, I m just asking does with the time, color can be **bleep**ed up or stay as it?
Hi @Mev22,
Sorry not sure what you mean here, was your question in regards to the colour of the phone?
Could you please clarify so we can help
I think he's asking what he can paint the sides of his XZ with where the paint has come off and left the white plastic showing.
Aside from removing all the paint and asking someone who is good at painting Airfix models to redo it all with Airfix paints, I have no idea. Using nail varnish would stick out like a sore thumb and probably rub off fairly easily.
The little white place I got is near the charge's place a bit, above it
Btw, cleaning phone with some alchool doesn't make any disadvantages?
A metal phone for me next time. Silver too, because they show the least amount of scratches. I'm done with plastic £550 phones.
Hi @Mev22,
We generally wouldn't suggest using any foreign substances on your device, so if you were wanting to "paint" over any wear and tear, this is something we would suggest against.
Also, using alcohol to clean the phone is also something we wouldn't suggest to do, a clean, dry lint free cloth would be best :smileysmileywink:
The place to be painted a bit is too far of the thumb or a key or the speakers, it's above the battery charge place
