Here the same!
regards
Herbert
Hi there,
Same thing here.
Mobile sell by Orange France, since Nougat update, time is reseted at each reboot.
I've found a tip:
disable "prompt for password / pin / scheme..." after reboot will fix this issue... but downgrade the security.
Sony want repair my mobile with RMA, lol, for a software issue.... i really don't beleive they can make someting on hardware...
Team Sony: if you want, I'm able to test any patch / beta etc...
Service Request: 1-29032942753
PS: your backup solution (on windows or direclty xperia) is not working.... it says backup is ok, but unable to restore (because sometime it's an application, or home screen or... it's not working )
have a nice day !
Same Problem here. (brand new XZ, got it yesterday).
39.2.A.0.361
After i turnend off and on again or restarted the phone, the date and time is wrong, Wifi has also problems until i enter the correct date and time....
