@darkeye This works, but hopefully doesn't compromise on safety of the device?
Just to reiterate what DarkEye has said so far :
1. Yes, after updating to 7.0 the clock resets to some strange dates, was 01 January 1970, now lately to 01 February 1970. So seems to be increasing over time.
2. No, Safe mode makes no difference.
3. No, I cannot test Repair because it does not work (another issue I will have to ask about).
4. Not asking for the Security check on restart (whichever preferred method you choose) does fix the date problem. I don't see this as a compromise as this is a new feature not there before, meaning all old software works fine without it, it just seemed like a nice addition.
Anyway, thanks DarkEye for figuring out the problem
