После обновления на 10 андроид исчез режим понарамной съёмки. Я пробовал сбросить все данные, восстановление программного обеспечения, но ничего не помогло. Почему такое ужасное обращение к своим пользователям сони?! Я уже не говорю проблемы связанные с дисплеем прогорание пикселей на верхней части панели. Когда уже решите эти проблемы? Уважайте своих пользователей!
After updating to 10 android, the mode of non-ram shooting disappeared. I tried to reset all data recovery software, but nothing helped. Why such a terrible call to their Sony users ?! I'm not talking about the problems associated with the display of burning out pixels on the top of the panel. When will you solve these problems? Respect your users!
-GT
Same problem here! Cannot remember delete any internal apps. I tried download camera3d from Internet but cannot install. Anyone else met same issue?
You will find on the internet "Sony Panorama 1.1.A.0.15" works for me. The Smart Lock "Trusted Face" option has also disappeared and you cannot unlock the phone with your face
My XZ2P also missing the panorama mode and time lapse mode.
It's work for me too, thx.
Otherwise, time lapse mode can be dl from the playstore.
These two function are the origin function from the beginning.
How come they gone after each update.
sonymobile = noob
