Since android upgrade to Oreo 8 phone not working properly have 2 phones keep switching off
Only way to get them to start is have to force restart of phones
Many apps not working properly or if at all
Can't clean storage to free up space
Since updating it as also wipe sd card
i think you better repair your phones using Xperia companion this will solved your problems
False, there's big problems with oreo sony stock rom, sony knows but it doesn't care until .75 was fine, after that just nightmare with some phones and firmware, you can check the forum
@Hakkinen3k I'm not having any problems on my XZP running Oreo, so perhaps the software repair is the way to go after all.
Companion for unlocked bootloader is useless, newflasher is the way but, some firmware are buggy as, so, i stay with nougat until 8.1... maybe.
Hi people
Thought I post to let you know
OK I tried Sony software companion on laptop
Phone wouldn't connect at all
Even after reinstall software on
Laptop?
Included reboot etc
So had to do a full on hard
Repair reinstall via holding volume down button and plugging in USB
To laptop
Took roughly 30 minutes
Then do reset to get phone up and running with Google Sony etc
The problem I found was could not do a backup before I did the hard reinstall so
I lost some call contacts and material I had on phone
I did have a backup on laptop but
Was out of date
And the over Google backup couldn't get a updated backup because of the issue of phone
Not even connecting to my Google account
So was annoying
Anyway at moment phone seems to be working OK
But still haven't put all apps back one
I do use Microsoft Office apps
But I'm a little bit worried so
I not using it on phone at the moment
Anyway like I said things seem to be working OK
I letting you know I resolved the issue via a forced reinstall
As Sony Companion wouldn't connect or phone
I've got both phones working OK
At the moment
But is very annoying to have to do
This the want to roll out Oreo 01 sooner than later and get rid of the bugs in Oreo 8
