Are we likely to get this feature via OTA at some point?
Hi @SR147, thank you for your question.
Night Light mode is supported in the Xperia XZ2 and Xperia XZ2 Compact and I don't have any information if this feature will be available for the Xperia XZ or other devices later on, however I understand that this feature is requested by a lot of users, so I will make sure to forward your wishes internally as user feedback!
It is possible to use a third party application to achieve a night mode/light effect, so you can always have a look in the Google Play store and see which applications are available!
I hope that helps and I'm sorry that I can't give you a more exact answer than this.
It would be perfect to add night mode practice for Xz
Hi @kaan22, that would be very helpful!
I'll make sure to forward your wishes as well as user feedback!
Have a great day!
Hello,
Maybe this can help you : http://www.xperiablog.net/2018/03/22/enable-night-light-mode-if-youre-running-the-march-2018-securit...
Tested on my XZ and working fine
