Please see the screen shots, what on earth is going on?! I have had the phone less than a week.
@Kovacs1 wrote:Please see the screen shots, what on earth is going on?! I have had the phone less than a week.
Hi, I am facing the same problem, any solution please?
same here, it happend after the latest update
What version are you using? Did you wait for about 2 days for the phone to optimize itself? The phone usually takes about 1-2days to fully get used to the new software.
I have the same problem with mine after the latest update. I used to go to sleep with 100% and wake up with 100% and now I go to sleep with 100% and sometimes in is close to 80-85%
wrote:I have the same problem with mine after the latest update. I used to go to sleep with 100% and wake up with 100% and now I go to sleep with 100% and sometimes in is close to 80-85%
If you don't mind, you can on Airplane Mode before you sleep, and then turn it back on when you wake up. This has 2 benefits, Sound notifications won't disturb you and You are less likely to use your phone.
Same problem here. Battery is drained after night without any obvious reason. Tried to reboot, but same problem at the next night.
