After installing the android 10 Update I have the following problems :
- The hole handy freezes sometimes. It looks like an overflow and all open apps don't working.
- The phone-app far too quiet.
- The fingerprint-sensor is not so reliable as in the earlier version.
- The camera-app freezes very often.
- The battery life is shorter than before.
- The allover performance is reduced.
- The gesture control doesn't work correctly.
- The most irritating problem is the Sound-problem in WhatsApp. Voice messages are impossible. The reciever can't hear anything. Very often the recording stops after 3 seconds.
I hope that you solve all the problems very very soon. Have you checked the update before publishing it? I am very disappointed!
Downgrade to Android 9
