Does your phone has an SD card? if it does, perhaps that ringtone is on it
You can send your suggestion to Sony directly >>> Local support, btw, scrolling through that menu it's quite easy.
Hi @Zinky,
Welcome to the community.
I have just checked this and you are quite right, both Merope and Tinkerbell are the same sound. I had never noticed this before.
We appreciate your feedback on both this and lifelog. Thank you!
