Hi @trashcan,
This seems to be related to your service provider (operator).
Do you receive this message when entering a code in the dialer pad to check status on how much data you have left for the month or something similar?
If you are receiving it when entering a code, try putting a "," at the end of the code.
So if the code is supposed to be #*123#*. Try entering the code as #*1337#*,.
If you experience this code in any other way, I would recommend getting in touch with your service provider.
Let me know if that helps!
Hi again!
If it didn't work with the "," I'm afraid that there isn't anything that you can do or change in the phone, since this is an error message from the network.
Do you have another SIM card from the same service provider that you can try with and see if you experience the same behaviour?
If you borrow one from a friend, colleague or similar, or if your service provider has a store where you live, they should be able to replace your SIM card(s).
Keep me posted!
Hi again!
If you switch the SIM cards, and do a new network search, is it only showing the networks with a home icon for the SIM card in slot 1 or is does it work correctly with one of the cards?
It's hard to say what is wrong, but these error messages are network related, so my best advice is that you contact the service provider that you experience the behaviour and if they have a local shop in your area they should be able to replace the SIM card or disable and enable it again or if they can send you a new SIM card.
Let me know how it goes!
Thanks for the update!
To reboot your phone in safe mode, press and hold the ON/OFF button, until you see the "Power off" menu, press and hold on "Power off" until you see a new window (takes 3-4 seconds) tap OK in the bottom right corner and the phone will reboot to safe mode.
To exit safe mode, simply restart your phone.
If this is indeed caused by the phone, and you experience the same behaviour in safe mode. I'd recommend that you perform a software repair using Xperia Companion before you visit an authorized service centre, just to rule out that this is caused by the software in the phone.
A software repair will delete all data stored on the internal storage, so creating a backup prior to starting with the repair is advised.
Keep me posted!
