Hi!
I'm afraid I'm not sure what would cause this. I've tested with a Qualcomm QC3 charger here and can unfortunately can't replicate what you are experiencing.
We can only guarantee that an original charger that comes with the phone will be fully compatible with your device, afraid we can not guarantee that other chargers will be compatible with our devices as we can only test using our own accessories.
I hear what you're saying and I'm sorry I don't have a solution for you, but unfortunately I will be unable to test the combination of accessories you are using as I don't have access to them here. Sorry for any trouble this may cause for you.
Does this happen to everything you charge in car? or just XZ? does this happen when you charge using the wallmount adapter?
Hi @Tsk362,
Congratulations on your new Xperia XZ!
Does the same thing occur with your Xperia XZ while charging via a computer? Meaning if you turn your computer off while charging your phone. Are you using the original USB-cable that came with the phone?
Hi!
Hello.
Thanks for reaching out, acknowledging my experience, for your comments and input. My interest in posting was to flag it and bring it to your attention. My work around is simply to use the other port, I accept that, and that's fine.
The device by the way is amazing!! Really happy with it.
Thanks again,
N.
