Guest mode seems to have disappeared or changed with the Pie upgrade for XZ1 compact. Does anyone know if it's possible to enable guest mode?
For guest mode:
Goto settings -> system -> multiple users
When you want to share the one app you're using with someone else you can consider screen pinning:
Settings -> security -> screen pinning
