Help. Buy or wait?
Emma08
Visitor
Help. Buy or wait?
Hi, question I'm a fan of you since the first Xperia Z. Currently I want to upgrade to the XZ premium. Do you recommend buying it or waiting for me to launch the new range top that has been announced for the beginning of winter? Please I would appreciate an answer thanks
Hola, pregunta soy fan de ustedes desde el primer Xperia Z. Actualmente quiero actualizarme al XZ premium. Me recomiendan comprarlo o esperarme a que lancen el nuevo tope de gama que lo tienen anunciado para el inicio de invierno ? Por favor agradecería una respuesta gracias
6 REPLIES 6
RizkyRizz
Visitor
If you love 5,5" screen size go for it
But i would say, take XZ1
or maybe if you dont mind about losing 3,5jack for headphone, go for XZ2 the latest flagship from Sony
dandy63
Leader
@Emma08 difficult to answer, XZ Premium is a great phone..... i also have an XA2 ULTRA which is also excellent, new models from any manufacturer arrive approx every 6 months so prices for earlier models will drop....if you're happy with not having the very latest then go for the previous model, whichever you choose you know you will have a great phone....good luck 😎
Emma08
Visitor
@dandy63 thanks for your help and if in fact have the best in range I am not interested however in my country the Xz premium is $ 700 in the cheapest place. Do you think that buying it at that price is reasonable since there is xz2 for approximately $ 70 more?
Emma08
Visitor
Thanks for the help. The xz2 does not call me much attention where the fingerprint reader is located. I'm thinking about waiting or buying the premium xz. But since you say it, why do you advise me on xz1?
dandy63
Leader
@Emma08 if the price difference is only $70 if you can afford it then that seems a better deal, re fingerprint sensor on the back I admit that having it on the back of my XA2 ULTRA seemed awkward to begin with as the XZ Premium is side mounted but you get used to it. Alternatively if you can wait/save for the newer model then do that.....just follow your gut instinct if you have the slightest doubt re models... Good luck🤞
Hakkinen3k
Visitor
Don't buy it, I regret buying xzp to much issues with no fixes besides of low volume, problemas with oreo, battery drain, lost connectivity data voice after a few hours, WiFi suddenly disconnect and can't reconnect ...a lot more.
