After the update to android 7 group contacts are not shown in contacts. You favourites and all are the only fields shown, but no groups? All my grouped contacts still have the group assigned but there's no way I can see to display the group?
Likewise you can no longer select a group to send a message to under the standard Sony messaging app.
Any ides?
it seems that contacts app was upgraded and the group feature was removed.. i'll try to get more information about this.
I have the same problem really is frustrating. If I go on Contact to display & my Google account I can see them there but can't do anything with them.
I noticed this right away as soon as I updated and it is very frustrating. I use group texting weekly and hope there is an easy way to get it back.
@PNM123 wrote:
Very annoying. I use groups to message parents of Scout group that I run. If Google contacts have the functionality then it should be available on your phone as well. Hope this is sorted quickly!
It depends on what functionality you are talking about. There are lots of possible functionalities that can be based on contact grouping. But the only thing Google's own devices support using "standard" apps is contact filtering: selecting which contacts to display in "standard" Contacts app. That's all. And this is exactly how it works now in Xperia XZ under Android 7.
Everything else were just "bonus" features implemented by Sony on their own accord. I don't know why they decided to remove these features now (time constraints, maybe?). But I'm sure you can always find a replacement messaging app that supports group messaging.
Even if they had contact filtering and then I can hit message all that would at least be a temporary workaround for me, but I can't seem to do that as well.
@Korben-Dallas wrote:It depends on what functionality you are talking about. There are lots of possible functionalities that can be based on contact grouping. But the only thing Google's own devices support using "standard" apps is contact filtering: selecting which contacts to display in "standard" Contacts app. That all. And this is exactly how it works now in Xperia XZ under Android 7.
It was the last system update I relly hope Sony sort it out as it really is a pain & a big backward step. I even sent back my xz phone but the new one is doing the same after the system update. Even the Sony helpline seem puzzled.
