Fingerprint scanner used to have 100 percent success rate before upgrade now it only works about 1/4 times.
I have the same issue. Please fix sony!
Same problem here... Xz2 premium
Me too.
Fingerprint response a lot slower than before.
Weird I'm not having problems with it.
Try reregistering your prints and see if it gets better?
I have the same issue with the fingerprint scanner. Reregistering my fingerprints didn't help to solve the problem.
The same happened to my XZ2 Premium
I too have this issue after updating to 52.1.A.0.532
There's a suggested solution: you can add FingerprintExtensionService to battery exceptions from the Applications (with system app...
I applied it and I haven't experienced a change, but you might want to try it.
