The fingerprint sensor on my XZ works wonderfully. Were you having such problems with it from the time you started using or did the problem escalate with the passing days? If it was inaccurate since new, it's probably a faulty sensor.
@AnP155 I'm sorry to hear this. If you can create a bug report and send it to me I can forward it internally for investigation.
To do this:
When the report is ready you will receive a notification. Tap the notification to share it. I suggest you upload it to Google Drive and then choose to share a public link to the upload and include the link in the PM.
@Elang You should only have to press the power key once, in order to wake the device. After you have pressed the power button to wake up your device simply keep resting your finger on the key without pressing it again and the device should unlock. If you press too hard, your fingerprint may be distorted.
