What is the function of having dual sim if it is not possible to use them together if you want to install external memory, does anyone know how to solve this manufacturing error of Sony?
Cual es la funcion de tener dual SIM card sin posibilidad de usarlas juntas si quieres instalar una memoria SD, alguien sabe como resolver este error de fabrica de Sony?
Thanks
Gracias
Impossible 😕
