I can send items (pics and vids) via NFC beam to another phone but..
I am having issues receiving items via NFC on my Sony XZ
It says "Item Not Found"
Please help!
files that are transferred using NFC are stored at Internal Memory>Beam, can you see if there are files in that folder?
are you sure that the transfer was complete? can you try beam again and make sure the nfc contacts are connected at all times.
I'm not very familiar with Samsung phones i'm afraid but i do think you might have two beam options in it. The Android native beam and Samsung S Beam. Please make sure that your Samsung phone is set to use the Android native beam. From what i could find on other forums, the S Beam will only work between Samsung phones.
