This is a USER based forum, you can NOT restored your data if you did NOT backed it up, I hope you respect the forum guidelines this time.
No, you are out of luck
On a side note: although other users can't see your removed posts (due to forum guielines violations), you should change your rude condescended behaviour, more so if you are looking for help.
You can request that to your Local support or factory reset your device with XC, it should restore them, OR check the XDA Forum, most likely someone has uploaded the files.
On a site note, do NOT request nor share private information, such as but not limited to emails, phone numbers, address, etc.
