Hi
Yesterday I tried to reset my phone with pc companion program. The reset has failed and phone after I try to turn it on show the message Your device has failed verification and will not work properly Your device will be powered off in 5 seconds. I didn't root or do anything with phone just wanted to reset. Pls help what to do ?
plug the charger let the phone for 2hours and try again repair in Sony Companion software . For me that works
Problem Solved .
how did you fix this ? ! would appriciate the help
