Dear all,
In few days ago I tried to set up 1 feature: unlock phone with Key Code or Finger Print and Google Assist Voice recognition.
I believed, It's a my fault, becouse I didn't activate that feature. Today I tried 2 method:
1st method: Activate Lock (PIN) + Google Assist Voice recognition
Result: cannot activate after press correct PIN. It dropped back a last page (activate feature) every tried.
2nd method (I discovered a bug during a method): Activated Assist Voice Recognition, Activated PIN security and when tried to activate "Unlock phone with Voice Recognition", my System has crashed and a hone has rebooted.
Can you have any idea, how I can activating Voice activation in lock screen?
More information: I'm beta tester a most of Google applications (Google Search, GBoard, etc.). Is it a source of my problem maybe?
Здравствуйте! После последнего обновления телефон периодически при блокировке экрана вырубается экран и не реагирует и не включает экран. При этом звонки и уведомления работают и издают звуки, а экран чёрный и что бы не делала не включает экран и не выключает телефон! Спустя короткое время при нажатии на кнопку отключения много раз начинает перезагрузку и включается! Пожалуйста исправти
Hello! After the last update, the phone periodically turns off the screen when the screen is locked and does not respond and does not turn on the screen. In this case, calls and notifications work and make sounds, and the screen is black and whatever it does does not turn on the screen and turn off the phone! After a short time, when you press the shutdown button, it starts rebooting many times and turns on! Please correct
GT
