Do you have Stamina MODE enabled? I think a week should be enough but you might want to wait few more days.
That's great to hear
it's an amazing phone.
Hi @Steve1970,
About 1-2 weeks is right, but it will be more accurate if your schedule is quite consistent. So if you always plug it in at roughly the same times every day it will learn quicker than if you charge it sporadically.
Hi, I bought my XZ more than 2 month. Usually charge my XZ from 22h30 and unplug at 6h30 but the battery care doesn't work.
I remember when I charged the 3rd time, battery care show up but I click on "changing the routime/the charge time (I don't remember exactly)", then each everytime I charge after that day, battery care not showing anymore.
Can anyone help me to find out what's happened?
If I continous charge XZ without battery care with my routine (22h30 - 6h30), will my battery be ok after all?
Thanks.
The battery will charge normally even without the battery care activated, think of it of just an added benefit.
Try to let your device relearn your routine, deactivate and reactivate battery care and charge the device during specific time. From my experience it will only give around 30 mins to an hour from the specific time you charge it to activate the feature
the description in the battery care settings, is that it will only detect when you usually leave your device charging for hours. so it will not count small time charges like maybe less than 30minutes (just a guess)...
