Problems I noticed after the upgrade:
1. Fingerprint running slow or at all
2. Sometimes there is black screen while calling and I have to wait for it to disappear by itself cause I can't turn it on
3. My XZ3 is connected with smartwatch via bluetooth (Smart Lock). After upgrade in 90% of cases I have to unlock the phone by PIN.
4. Not everything in Settings is in Dark Mode, for example Smart Lock.
And, of course, where are Android 10 gestures? And why we still have old Sony Launcher with strange swipe down search option, which is useless?
Oh, Ambient Mode in XZ3 is useless also, cause displays outdated notifications.
Finally, thanks for the beta version you tested since last spring... Anyone want's to buy my XZ3?
I am having real issues with alarms since the latest update. Alarm goes off, I dismiss it off then a minute later it goes off again. I have even switched the alarm off and it still goes off again! Plus battery drain is now really bad and charging takes ages. Not impressed any idea when bugs will be fixed?
Next month... 90%
Same problem with alarm.
Same here mate. Alarm has happened twice and the battery is on its by 2pm
Have they communicated this mate?
Try doing a factory reset. It worked for me... 😜
I completely agree, where are those launchers. This is not the real Android 10 without them, it's part of the software why have we been given only a PART of it.
I'm also using the Xperia XZ3 and this device is only a year old, not to mention I'm also having issues. Screen freezes and slows down every now and then, apps open slow at times. And finally, I'm dissapointed to see ZERO changes in the camera app, not even image quality improvements - with Kimio Maki in charge I thought I would see software improvement changes on that area, and it turns out there is nothing. Bad, bad service - it's only been the first REAL update and this is what we get - a BETA software.
I have the same problem with alarms, if alarm is snoozed it pops like every minute but snooze options is fixed to 10 mins. When alarm starts sometime i cant cancel it it just pop up again after few minutes.
Over all the phone now is much slower then before the update and conection is poor for some reason.
Not able to make or receive calls. The other side simply cannot hear me. After restart. It may work for some tens of minute and then fails again.
