Clock
Every day I get a message from the clock app in the notification bar about a delayed alarm at 20:59 that does not allow me to remove it from the discard button or to the side, apart from that I set an alarm at that time. Does anyone have an idea or does the same thing happen to him?
Reloj
Cada dia me aparece un mensaje de la app de reloj en la barra de notificaciones sobre una alarma postergada de las 20:59 que no me permite quitarlo desde el boton de descartar ni hacia el costado, aparte janas estableci una alarma a esa hora. Alguien tiene idea o le sucede lo mismo?
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
settings > apps > app info > clock > storage > clear data > check again.
Thank you very much!! I would try it!!
