The system wants to format my SD card, but as I've got programs and a lot of podcasts installed, I'm quite irate about this.
Is this an error, or have the accepted format changed?
Either way, please inform users before they choose to install the update.
Sincerely,
Anders Bering Bøgh
This happened if you encryption your SD card in old firmware... Then clean install new firmware (like wipe then OTA or flash with FTF file)
You must deactive encryption from "Settings > Lock screen & security > encrypt SD card" and backup your data to PC, then upgrade.
And sorry: you lose all data saved on SD! Formatting stroger is the real solution.
