I use Polar Flow app to synchronize my training sessions from Polar V800 to the web:
Polar V800 - bluetooth 4.0 - mobile - https - flow.polar.com
I have upgraded from Z3 compact to Z5 compact. Nothing else changed.
Since then the synchronization is almost impossible. The syncing process fails after 30-60 seconds every time. If I am lucky the current training session can be uploaded to the mobile after 5-10 attempts.
Bluetooth HCI snoop log was fine on Z3 compact but not on Z5 compact. Wireshark detected some inconsistencies in the Z5C's bluetooth log: it has been cut short in the middle of a packet.
So I think the bluetooth connection drops very often during data transfer.
Similar problem here.
If i use my Z5 compact with lg g watch R android wear for my Runtastic's sessions the data on LG work for 10/15 secs then disconnect for 2/3 mins, then reconnect for 10/15 secs and so on.
On phone display the B icon on status bar disappears, then come back. My Cardio disconnect in the same time of LG.
HOW THIS IS POSSIBILE?
I opened another thread for GPS problem...not resolved!
Now BT Problem...
This Z5 Compact is the worst phone i ever had...
Sony has the worst customer care i've ever seen...
I have suggested something but I haven't seen the results on your post
Have you contacted the app developers?
Have you contacted Sony directly? Local support ? again, this is a user based forum, in other words, this forum is for us, users, to help each other.
I wrote to Runtastic....but the SAME things happend with Runkeeper.
I contacted Local Support (this is my id case: 1-22326941966) .... can't help me
I don't have any time to spend for this bad device...i hope i can change it as soon as possible (but not with another sony...)
i tried...but i can't find a map or gps functionality...am i wrong?
But...i tried 3 other apps...please...
The BT issue is popular...
http://forum.xda-developers.com/xperia-z5/help/bluetooth-issue-t3241511
I think the problem is throw...do you know i can disable it?
You might want to check on the XDA forum http://forum.xda-developers.com/xperia-z1/help/how-to-totally-disable-throw-causes-t2860830
