Hello,
I want to buy a MicroSd card for my X2 and i am wondering what is the hardware data rate when using a microSd card and which class does it fit?
Thanks
You can use class 10 but I dont know if the X2 can take fully advantage of the speed. I think 16 Gb is max memory the X2 can handle.
