Hello,
i've got some very strange issues with the roaming behaviour with the Xperia X
Actually i've got 35 Xperia and none be able to roam correctly... all wait when the signal comes to low to change the ap..
The wifi is ok, ( all the 802.11k, r ... and so one is activated )
For example, with a Nexus and an Iphone is ok...
https://productforums.google.com/forum/#!topic/nexus/93GcQ8O75q8
http://forum.xda-developers.com/galaxy-s3/general/fix-wifi-roaming-bug-t2015482
http://gs3.wonderhowto.com/how-to/fix-wi-fi-roaming-bug-your-samsung-galaxy-s3-0140840/
Does anyone tested it ?
many thanks in advance
Nobody tested this solution?
Hello,
Nobody experiencing the same issue ?
It's not something that i've experienced myself.
Does the connection stop working in your phone as you move around or is it that you expect it to roam sooner than it does to keep a better signal strength?
At the location i'm currently at, we have multiple access points. I'm connected to a SSID available on all of them and as i move around the building i roam between the access points without any problem. It seems there may need to be a certain difference in signal strength before it roams though. I'll see if i can get more information on at which point it will roam.
