X10 Sim Card Required?
Not applicable
I'm getting an X10! I wanted to know what I have to buy separately, such as Sim card, microSD, etc.
Thank you!
-I<3X10
2 REPLIES 2
sushidushi
Contributor
What comes in the box with the phone varies a bit, but I am pretty sure that the phone will always come with a microSD card, but not a SIM card, so you will have to sort that out separately.  Mine didn't come with a case, but I know that others' phone had a case included.  The main thing will be the SIM card from your mobile phone company, without which you will be able to do nothing...
Rocco1
Visitor
If you're buying from you network provider and upgrading your mobile you will get a sim card, a microSD card and a case of a sort, that some people will be happy about, but others like me, what another type of case. But these are easy and relatively cheap to buy.
