i have a x10 mini pro with a couple of problems firstly a padlock shape icon has apeared in the status bar can anyone help me to find out why it has appeared and how to slove the problem secondly i cant find a decent user guide for this phone given a good discrition of the phone many thanks boris
Hi Boris,
To find out what the padlock indicates, I would suggest dragging down the notification bar on your handset. Where the padlock is shown, if you drag your finger down the screen, you should see a description of why this is here.
With regards to the User Guide, an extended User Guide is available for download here: http://www.sonyericsson.com/cws/support/phones/detailed/userguide/xperiax10minipro.
I hope this helps you.
