Hello,
I found the battery information is not displayed correctly.
I just checked it recently and is told me the most battery life was taken by Antutu as shown below, ok then:
but then I saw how much battery was taken by this app, and it says 7608mAh:
Did Sony by mistake inserted much bigger battery in my device?
I would be very lucky then hehe.
By the way for screen it says 239mAh was taken for 1h 55 mins 8s SOT (screen on time).
Thank you.
well unfortunately that wouldn't be possible. more maH equals more size..
try to reinstall that app, or you can contact the developer to submit this bug.
i currently don't have data regarding how much maH should the screen be normaly be using, but you can try to observe this by taking notes of those data after each charging
Same thing happens to me with pokemongo, must be a software bug that is reporting wrong battery usage
