On my previous phone it was possible to use the Wi-Fi network you're connected to for location tracking purposes without GPS needing to be turned on. Is there any way that I can turn location tracking on permanently without having GPS active the entire time?
Hi @KyleTheramor, welcome to the community.
For this handset, you will require Location services to be enabled in order to do this, so it needs to use GPS in some form.
